GetAWSNIC (AWS Network Interface (NIC))
This method is used to return the list of AWS NICs in HCL BigFix CLM.
Method Signature:
GetAWSNIC(regionName, instanceId, subnetId, controlId, async, servicePlanId, callback, addlparam)
Sample Response:
[{"Value":"9","Name":"eni-0adc5ad816f05292a","RegionName":"us-east-1","text":"eni-0adc5ad816f05292a"},{"Value":"16",
"Name":"eni-08e2a3edeb0bd56a8","RegionName":"us-east-1","text":"eni-08e2a3edeb0bd56a8"}]
Parameter Details:
| Parameter Name | Type | Mandatory | Description |
| RegionName | String | N |
If the region name is passed, then details of passed region’s NIC are returned. If blank “” is passed, then detail of all AWS’s NIC will be returned/bind to the control. |
| instanceId | String | N |
If Instance ID is passed, then details of passed Instance Id’s NIC are returned. If blank “” is passed, then detail of all AWS’s NIC will be returned/bind to the control. |
| subnetId | String | N |
If Subnet ID is passed, then details of passed Subnet Id’s NIC are returned. If blank “” is passed, then detail of all AWS’s NIC will be returned/bind to the control. |
| controlId | String | N |
Id of ‘Select’ control to be populated. If Id Control of dynamic UI is passed, then control will be populated with values return from this function else “Result set” will be returned in JSON format. |
| async | Boolean | N |
In case it’s False: Function will be called in synchronous mode. i.e., Current execution will wait for method execution to complete In case it’s True: Function will be called asynchronously. Execution will not wait for method execution completion. It will jump to next statement. |
| servicePlanId | String | N | Service Plan ID is a plan related to cost model created by provider and map to the resource in HCL BigFix CLM. |
| callback | Function | N | Users can passa function name that can be executed on completion of Parent function call. |
| addlparam | Object | N |
Addlparam is used for filtering and sorting the records. It contains 3 properties filter/sortby/sortorder. To Filter: To filter records based on column name received from output. e.g., filter="keyname='keyvalue'" To Sort By: To sort the data based on column name. e.g., sortby="keyname" To Sort Order: To define sorting order either ASC (Ascending) or DESC (descending). e.g., sortorder="ASC” |
