Flow variables example
See the Flow variables example for a demonstration of how to use flow variables in a flow.
The Flow variables example contains a readme file that contains detailed instructions about how to run the example.
The example is located in the following directory:
install_dir/examples/flowengine/flow_variables
Where install_dir indicates the directory location of the base HCL Link product.
To install this example, as well as the other flow examples, you must install HCL Link
using the Custom installation.
