Error and Success terminals example
The Error and Success terminals example demonstrates usage of Error and Success terminal used in a flow.
The Error and Success example contains a readme file that contains detailed instructions about how to run the example.
The example is located in the following directory:
install_dir/examples/flowengine/error_success_terminals
Where install_dir indicates the directory location of the base product.
To install this example, as well as the other flow examples, you must install Link using the Custom installation.
