Server section options
The server drop-down in the Run Properties dialog allows you to specify these options:
Run on Design Server – Set this toggle to either run the flow directly on HCL Link, or to deploy it to a runtime server.
Server – If you are deploying the flow to a runtime server, select the server from the drop down list. The servers in this list are defined in the Deployment screen. Only servers that are defined as Local or Web type will be listed.
