Variable Scope
Variable Scope specifies the target for the path expressions.
It can be set to one of these values:
- Flow Variables – Set flow variables.
- Cache – Set cache variables.
- Set no Variables – Do not set any variables. Use this option if you want to filter the input JSON and have no need to set flow variables or cache variables.
