Importing data from local file system
If you have data or a sample file, you can import it into your project and can use that data to design a schema.
- You must have created a project.
- You must have a data file in your local file system in CSV or Excel files.
The Files tab on the Data Fabrication page is one of the design components of a project. By clicking this tab, you can create a file. This tab helps you to import an existing file from the local file system, for which you want to generate test data.
- Log in to HCL OneTest™ Server and open the team space that contains your project.
Open your project.
Click .
- Click the Files tab.
Click New from the to create a file.
The New File dialog is displayed.
- Select a file that you want to import from your local file system.
- Provide a name to a file, folder details, keyword as Tag for quick search, and a brief description of the file.
- Click OK to import and create a file.
You achieved the following results:
- View the list of all the files imported for this project in the Files tab.
- Use the Search field to search any file from the existing files.
- Sort the list of files by name, folder, and recently used files.
What to do next
Importing files into schema designer
To create a schema by using the data you imported, you must import the data file into schema designer.
When you want to create a schema, you require data. You can use the data which you have imported from your local file system.
Click Import from the .
The Import dialog box is displayed.
- Select the file type as CSV.
- Select the file that you want to import from the Sample File Path and define the import properties of the data.
Provide a schema name for this data and click Import.
The schema appears in the schema designer.
- Save the changes.
You can view the imported file listed under the tab.
