HCL OneTest Data support to generate test data for SAP BAPI
When you want to generate test data for SAP Business Application Programming Interface (BAPI), you can generate a schema in HCL® OneTest™ Data based on structured schema of SAP BAPI function modules. You can then generate the test data by using the generated schema in HCL® OneTest™ Data.
SAP BAPIs are API methods of SAP Business Object Types. HCL® OneTest™ Data uses SAP BAPI to access the application layer of the SAP System.
Prerequisites
You must have access to HCL OneTest™ Server.
Task flow
You must perform the following tasks in sequence to generate the test data for SAP BAPI in HCL® OneTest™ Data.
The table also provides you the links to the information about the tasks:
| Task | More Information |
| Install SAP connector files in HCL® OneTest™ Data | |
| Establish an SAP BAPI connection with HCL® OneTest™ Data | |
| Generate a schema in HCL® OneTest™ Data | |
| Generate test data in HCL® OneTest™ Data | Generating test data |
