Troubleshooting installation issues
You might encounter issues when you access HCL® OneTest™ Data after you install HCL OneTest™ Server for the first time. You can find details about the issues, their causes, and resolutions to fix those issues.
| Problem | Cause | Solution |
| When you access HCL® OneTest™ Data after you install HCL OneTest™ Server on the Kubernetes environment (k3s) or Red Hat OpenShift server for the first time, you might encounter an error stating that the page cannot be loaded. |
The pods such as HIP Server and Data app might have failed to run successfully. |
You must restart the pods by using the following commands: For HIP Server on k3s environment
For HIP Server on Red Hat OpenShift server
For Data app on k3s environment
For Data app on Red Hat OpenShift server
Where |
| When you generate a test data after you install HCL OneTest™ Server on the k3s environment or Red Hat OpenShift server for the first time, you might get a page that displays Error. | The pod such as HIP Rest might have failed to run successfully. | You must restart the pod on the k3s environment by using the following
command:
Use the following command to restart the pod on the Red Hat OpenShift server:
Where |
