Task flows for working with a system model
You can find information about the tasks that you must perform when you want to create a system model, associate the components, create linkages among the components, and then publish the system model to the team space repository. Also, you can find information about the tasks that you must perform when you want to modify an existing system model.
Task flow for creating a system model
You must follow the tasks in this task flow to create a system model for the application under test.
| Tasks | More information | |
| 1 | Configure a team space repository. | Adding a repository to a team space |
| 2 | Create components. | Creating components |
| 2.1 | Associate child components. | Creating and associating child components |
| 2.2 | Define the relationship between the components. | Editing components |
| 3 | Associate virtual service resources with components. | Associating resources with components |
| 4 | Run virtual services. | Viewing resources associated with components |
| 5 | Publish the system model. | Publishing the system model |
Task flow for modifying an existing system model
You must follow the tasks in this task flow if you want to modify an existing system model for the application under test.
| 1 | Create additional components. | Creating components |
| 3 | Publish the system model. | Publishing the system model |
