Establishing an SAP IDoc or DXOB interface connection with HCL OneTest Data
When you want to generate a schema for an SAP IDoc or DXOB file, you must establish a connection with the SAP IDoc or DXOB interface.
- Select your project in Rational® Test Automation Server and navigate to the Data Fabrication page.
- Click Connections.
Click New to create a new connection type.
- Select SAP IDoc from the Type drop-down list, and then click Next.
Set the following properties under Connection Properties:
- Enable Bypass Client Connection.
- Select 2 (Unicode) as Bytes Per Character.
- Click Next, and then provide a name to the established connection.
Click OK.
You can see the name of the SAP IDoc connection under the Connections tab.
You have successfully established the connection between HCL® OneTest™ Data and the SAP IDoc or DXOB interface.
