Establishing an SAP BAPI connection with HCL OneTest Data
When you want to generate a schema for SAP BAPI, you must establish a connection between HCL® OneTest™ Data and SAP BAPI.
- Select your project in Rational® Test Automation Server and navigate to the Data Fabrication page.
- Click Connections.
Click New to create a new connection type.
- Select SAP BAPI from the Type drop-down list, and then click Next.
Set the following properties under
Connection Properties, and
then save the changes:
- Enter the SAP System host name in the Host ID field.
- Enter Client Number and System ID of the SAP System.
- Provide the SAP System credentials in the User and Password fields for authentication.
Go to the Connection
Properties pane of the Data
Fabrication page, and then click
Test to verify whether the
connection is established successfully.
Note: Your connection might fail to establish because of any one of the following reasons:
- Trouble at the SAP server port.
- Firewall blockage between Rational® Test Automation Server and the SAP server.
- Unsuccessful copying of the connector files.
- Unsuccessful refresh of the HIP Server pod.
- Click Next, and then provide a name for the SAP BAPI connection that you established.
Click OK.
You can view the name of the SAP BAPI connection under the Connections tab.
You have successfully established the connection between HCL® OneTest™ Data and SAP BAPI.
