Data design environment overview
The data design environment is a graphical interface to design all its components and data generation rules to generate test data on user demand. You use various components to structure data in HCL OneTest™ Data.
The components of data design environment are:
  • Files
  • Connections
  • Schemas
The definitions of data stored in the schemas are used to define a map. The map specifies the transformation logic in the form of rules. The map identifies the data definition of a schema, validates the type properties of data by using rules, and compiles the rules to generate the real-time test data.
You can refer to workspace management to manage workspace in HCL OneTest Data.
