Deploying by using the Job Monitor
You use the Job Monitor to submit jobs and to monitor the job status in your deployment. You must ensure that you have a Job Monitor task running and that you run the HCL DevOps Deploy (Deploy) process to submit or to monitor the job. Then, you must set up Job Monitor connection properties in your HCL DevOps Deploy (Deploy) environment.
Install the following agent or product and use the Job Monitor that is bundled with it:
  • z/OS agent
  • IBM Developer for IBM Z
  • IBM Rational Team Concert
For the z/OS agent, the Job Monitor is installed automatically in the hlq.SBUZAUTH data set. Also, the LOOPBACK_ONLY property must be set to OFF in the Job Monitor configuration file.
The hlq.SBUZSAMP(BUZJJCL) member has the sample PROC for starting JMON. The hlq.SBUZSAMP(BUZJCNFG) member is the JMON configuration file that is referred to in the PROC. JMON installed for another product (for example, IDz or IBM RTC) can be used, but the LOOPBACK_ONLY property must be OFF
Submitting and monitoring jobs in deployment processes
  1. Start the Job Monitor task and check that a task that is called JMON is running.
  2. To submit or to monitor jobs, run the process that uses the Submit Job or Wait For Job steps.
  3. Set the following Job Monitor connection properties in the Deploy environment or resource:
    jes.host=localhost
    jes.user=z/OS user ID
    jes.password=Password of the user. Set blank to use PassTicket authentication.
    jes.monitor.port=The port number for Job Monitor host server.
    The default port is 6715.
Authenticating with a user ID and Password
To use a password to authenticate, store the password in the jes.password property.
As you complete the Submit Job or Wait For Job step, do not store the password directly in the Password field. The Password field contains plain text only and this field must be used to reference a property.
Authenticating with PassTickets
If you do not provide a password, the plug-in uses PassTickets authentication. You can use PassTickets authentication to eliminate the requirement to store user passwords in Deploy.
To configure your system to use PassTickets, complete the following steps:
  1. Activate the RACF PTKTDATA class if it is not already active. The following code shows sample RACF commands:
    SETROPTS GENERIC(PTKTDATA) SETROPTS CLASSACT(PTKTDATA) RACLIST(PTKTDATA)
    RDEFINE PTKTDATA IRRPTAUTH.FEKAPPL.USER1 UACC(NONE)
  2. To create a PTKTDATA profile that defines the secret key and the application name to which it applies for the Job Monitor, complete the following steps:
    1. Define the application name as FEKAPPL.
    2. Define the key as a 64-bit number (16 hex characters).
    3. Replace the key16 placeholder with a user-supplied 16 character hex string (characters 0-9 and A-F) as shown in the following sample RACF commands:
      RDEFINE PTKTDATA FEKAPPL UACC(NONE) SSIGNON(KEYMASKED(key16)) APPLDATA('NO REPLAY PROTECTION – DO NOT CHANGE') DATA('URBANCODE DEPLOY')
      The following example shows the command with the key16 value replaced:
      RDEFINE PTKTDATA FEKAPPL UACC(NONE) - DATA('URBANCODE DEPLOY') - APPLDATA('NO REPLAY PROTECTION - DO NOT CHANGE') - SSIGNON(KEYMASKED(0123456789ABCDEF))
    4. Read the following scenarios:
      1. If the PTKTDATA class is already defined, verify that it is defined as a generic class before you create the profile that was shown previously. The support for generic characters in the PTKTDATA class is new in the z/OS V1.7 release, with the introduction of a Java interface to PassTickets.
      2. If a cryptographic product is installed and available on the system, you can encrypt the secured sign-on application key for added protection. Use the KEYENCRYPTED keyword instead of the KEYMASKED keyword. For more information, see the Security Server RACF Security Administrator's Guide (SA22-7683).
      3. If the Rational Developer for System z or the Rational Team Concert server components are already installed on the system, the PTKTDATA profile might be defined already.
  3. To define a profile to generate a PassTicket, you must define the IRRPTAUTH profile in the PTKTDATA class. Then, this profile controls for which user ID a PassTicket is generated, as shown here:
    Operation Profile name Required access
    Generate PassTicket IRRPTAUTH.application.target-userid Update
  4. To set permissions for the Deploy agent to generate a PassTicket so that the agent generates a PassTicket, the user ID of the agent or the impersonated ID must have UPDATE access in the PTKTDATA profile that you created in the previous step. For more information, see the following RACF commands:
    PERMIT IRRPTAUTH.FEKAPPL.USER1 CLASS(PTKTDATA) ID(AGNTUSR) ACCESS(UPDATE)
  5. To refresh the PTKTDATA class for the new profiles and permissions to take effect, see the following commands:
    SETROPTS RACLIST (PTKTDATA) REFRESH
Example
See the following PassTicket examples:
Example 1. Agent is started by user AGNTUSR. In a deployment process, a Job needs to be submitted on behalf of user USER1.
Example 2. Agent is started by user AGNTUSR. Allow this agent to submit jobs on behalf of any user.
RDEFINE PTKTDATA IRRPTAUTH.FEKAPPL.* UACC(NONE)
PERMIT IRRPTAUTH.FEKAPPL.* CLASS(PTKTDATA) ID(AGNTUSR) ACCESS(UPDATE)
Example 3. Agent is started by user AGNTUSR. Allow this agent to submit job on behalf of user AGNTUSR:
RDEFINE PTKTDATA IRRPTAUTH.FEKAPPL.AGNTUSR UACC(NONE)
PERMIT IRRPTAUTH.FEKAPPL.AGNTUSR CLASS(PTKTDATA) ID(AGNTUSR) ACCESS(UPDATE)
What to do next
More JES security considerations are described in the IBM Developer for IBM Z documentation. For more information, see JES Security.
Authenticating with Trusted IP
Starting with v2.9.17 or higher, JMON can authenticate client IP as a trusted source and process client requests. This allows the Wait for Job and Submit Job plug-in steps to run with Agent User Id or Impersonation Id. The User Id and password/pass-ticket that are usually needed for these steps are ignored and hence can be left empty. If the client (z/OS UCD Agent in this case) is on the same system as JMON then no changes are required. But if JMON is active on another system in the SYSPLEX, TCPIP RACF profiles are required.
While it is recommended to execute JMON as a started task, it is also possible to execute it as a user job. When not active as a started task, JMON will query your security product for explicit permission to start.
Security profile Required access
BUZ.START.BATCH.jobName.port READ
The security class where this profile resides can be specified with SAF_CLASS variable in the BUZJCNFG configuration file and is FACILITY by default. When the profile is not defined, or the class is not active, permission is denied, and batch startup will fail.
Use the following RACF commands to allow USER ID (IBMUSER in this case) to start JMON in batch with job name JMONJCL and port 6715:
RDEFINE FACILITY BUZ.START.BATCH.JMONJCL.6715 UACC(NONE)
DATA('Start JMON in Batch')
PERMIT BUZ.START.BATCH.JMONJCL.6715 CLASS(FACILITY) ACCESS(READ)
ID(IBMUSER)
SETROPTS RACLIST(FACILITY) REFRESH
