System settings
System settings allows you to manage global settings for components, clean up, password requirement, security, mail-server, and much more.
| Field | Description |
| External Agent URL* | Specify the URL that the HCL DevOps Deploy (Deploy) server
provides to agents as their point of contact. When an agent wants to contact the server, it retrieves this URL and opens a connection on it. This URL must point to the HTTP or HTTPS port of the server. |
| External User URL* | Specify the URL that users enter to connect to the Deploy server.
The URL is also used when creating a notification template. |
| Message of the Day | Enter a message that will be displayed on user login or user navigation within web UI. |
| Validate Agent IP | When enabled, the agent IP and host name are validated against values that are used the first time that the agent is connected to the Deploy server. |
| Skip Property Updates for Existing Agents | When enabled, as the new agents come online, the
server does not update their properties. This improves the performance, but the agent properties can become out of date. |
| Create Default Children for Plugins | When enabled, empty groups are created when plug-ins use the auto discovery feature. |
| Default Locale | Select a default language for the user interface. |
| Default Snapshot Lock Type | Determines the default lock type when users create snapshots. Lock types are the following values: Only Component Versions, Only Configuration, or Component Versions and Configuration. The default value is Component Versions and Configuration. Changes are effective after the server is restarted. |
| Require a Comment For Process Design Changes | When enabled, prompts users to provide a comment when a process design is updated. |
| Enable Maintenance Mode | When enabled. stops activities on the server so you can run important tasks that require the server to be idle. |
| Components copy to CodeStation by default | When enabled, newly created components copy artifacts to
CodeStation by default. You can change this setting on individual components even when this option is enabled. |
| Enforce Deployed Version Integrity | When enabled, deployed component version artifacts cannot be changed. |
| Automatic Version Import Check Period (seconds)* | Specify the time-period (in seconds) between the times that Deploy polls
components for new versions. If this value is changed, the server must be restarted before the change becomes effective. You can set this value to 15 seconds or higher. |
| Use Agent Tag For Integration | When enabled, allows agent that is identified by a specific tag
to import component versions. If this setting is selected, the Agent Tag for version imports field is shown. Otherwise, the Agent for Version Imports field is displayed. For information about tagging objects, see Adding tags to objects |
| Agent for Version Imports | Specify the agent that is used to import component versions.
The agent must have access to component artifacts. The agent becomes the default agent for new components. This value can be overridden when a component is created. This field is displayed if the Use Agent Tag for Integration toggle button is set to Off. To import artifacts from the server location, install an agent in the same location and specify that agent. |
| Version Import Records to Retain | Specify the number of version import records to retain during cleanup. Default is 100. |
| Enable Safe Edit of Component Processes | When enabled, you can test component processes before making them
available in normal environments. You can make updates to your component process, test those updates safely, and then promote to a new version when you are ready. |
| Require Approval to Promote Component Process | When enabled, any draft component process must be approved by an authorized user before it can be promoted and used in deployments. |
| Allow Process Locking | When enabled, users with 'Manage Process Lock' permission can
lock component processes for editing. Users can also force unlock a process locked by another user. |
| Require Process Locking | When enabled, users will not be able to edit component processes without locking the process first. |
| Server Storage Display '100%' Size (MB) | Define the size in megabytes of '100%' storage in the
dashboard server storage display. This setting only affects the dashboard display and does not enforce a limit for artifact uploads. |
| Daily Cleanup Start Time* | Enter the time when versions are cleaned. The value must be an integer from 0 (midnight) to 23 (11 pm). To preview the component versions that are scheduled for cleaning, click Preview Version Cleanup. See Cleaning up component versions. |
| Default Application Snapshot Retention (days)* | Enter the number of days application snapshots are kept by
default. A value of |
| Default Version Retention for Component (days)* | Enter the number of component versions to keep by default. A
value of |
| Default Number of Versions to Retain for Component* | Enter the number of versions to retain for each component. |
| Default Version Retention for Environment (days)* | Enter the number of environment versions to keep by default. A
value of |
| Default Number of Versions to Retain for Environment* | Enter the number of versions to retain for each environment. |
| Archive Path | Specify the path where the compressed file that contains the
archived component versions is written. If this field is blank, the compressed file is not written, and no archive is kept. |
| Preview Version Cleanup | Click Preview Version Cleanup to see the versions that are archived using the current settings. See Cleaning up component versions. |
| Daily Cleanup Start Time | Specify the time that the daily cleanup process starts. |
| Daily Cleanup Duration (hours) | Specify the number of hours that the cleanup process runs daily. |
| Enable Deployment History Cleanup | When enabled, deployment history files are reduced. See Cleaning up deployment history files. |
| Days to Retain Deployment History | Enter the number of days to retain deployment history. This setting can be overridden with the related environment setting. |
| Enable Generic Process History Cleanup | When enabled, the generic process history files are set to delete as per the Days to Retain Generic Process History setting. |
| Days to Retain Generic Process History | Enter the number of days to retain generic process
| Enable Process Step Log Cleanup | When enabled, the process step log cleanup starts.
The process step logs are deleted according to the values that you set without deleting other history records. |
| Days to Retain Process Step Logs | Enter the default number of days to retain process step logs for generic processes not associated with deployments, and for environments if the number of days is not specified directly in the environment settings. Valid range is 0 or greater. |
| Enable Audit Log Entries for Read Events | This option is enabled by default. When disabled, no READ events are recorded in the audit log. |
| Enable Audit Log Cleanup | When enabled, audit log entries older than the number of days specified in the
Days to Retain Audit Log Entries field are removed beginning
at the time specified by the Daily Cleanup Start Time field.
See Configuring log rotation settings. Deleting audit logs from creates a log entry of event type Audit Log Cleanup that are non-deletable. |
| Daily Cleanup Start Time | If Enable Audit Log Cleanup is enabled, specify the time the audit log
cleanup starts. The default value is 12:00 AM. |
| Days to Retain Audit Log Entries | If Enable Audit Log Cleanup is enabled, specify the number of days
that audit log records are retained. The default value is 30. |
| Minimum Password Length* | Define the minimum length for passwords. |
| Require Uppercase Characters in Passwords | When enabled, passwords must contain at least one uppercase character. |
| Require Lowercase Characters in Passwords | When enabled, passwords must contain at least one lowercase character. |
| Require Special Characters in Passwords | When enabled, passwords must contain at least one special character. |
| Require Number Characters in Passwords | When enabled, passwords must contain at least one numeric character. |
| Require Password to be Unique From User Information | When enabled, passwords must not match username, actual name, or configured email. |
| Discovery Auth Token Expiration Delay(seconds) | Specify the delay in seconds for auth tokens that are created for
Auto Discovery Steps to expire. The value must be 300 seconds or more. |
| Configure Auth Token Expiration Delay(seconds) | Specify the delay in seconds for auth tokens that are created for
Auto Configure Steps to expire. The value must be 300 seconds or more. |
| Version Import Auth Token Expiration Delay(seconds) | Specify the delay in seconds for auth tokens that are created for
Version Import Steps to expire. The value must be 300 seconds or more. |
| Plugin Step Auth Token Expiration Delay(seconds) | Specify the delay in seconds for auth tokens that are created for
plug-in steps to expire. The value must be 300 seconds or more. |
| Use Default Auth Token Restriction if not specified | When enabled, the default authentication token restriction for
processes that are created in Deploy is used.
For these versions, the default token is applied to the most current process version but not other versions. For more information, see Restricting authentication tokens. |
| Require Token Restriction | When enabled, the None option is
removed from the Auth Token Restriction drop-down when creating or
editing an authentication token. This makes Auth Token Restriction a required field, but the user can still set a highly permissive token restriction. |
| "Remember me" duration (hours) | Specify the number of hours a user can optionally be remembered and remain logged in. |
| Logout should invalidate all "Remember Me" cookies | When enabled, invalidates all "Remember Me" cookies for a user when they explicitly log out. |
| Default Teams for New Objects | Select All Teams Available to
User to add all teams that are available to user by default when a new
object is created. When set to None, no teams are assigned to the users when new objects are created. Users can override this setting while creating objects. |
| Trusted proxy list | Enter a regular expression pattern to match IP of the
trusted proxy servers. This value affects all servers. You must restart the servers for the changes to reflect. If left blank, the proxy headers are not trusted from incoming connections, which further may affect auth token IP restriction validation and IP logging. |
| User Idle Days to Lock | Specify the number of days after the user's last
login date before locking the user account. You can enter 0 to disable user account locking. |
| User Idle Days to Delete | Specify the number of days after the user's last
login date before deleting the user account. You can enter 0 to disable user account deletion. |
| Preview Idle User Lock | Click Preview Idle User Lock to load the information about user accounts that will be locked or deleted. |
| Mail Server Host | Enter the host name of the mail server that is used for
notifications. Deploy can send notifications to users based on user-configured trigger events (to set up notifications, see Creating Notifications in a Notification Scheme). Deploy requires an external SMTP mail server to send messages. To disable notifications, leave the field blank. |
| Mail Server Port | Enter the SMTP port that is used by the notifications mail server. |
| Secure Mail Server Connection | When enabled, the SMTP server connection is secured. |
| Mail Server Sender Address | Enter the sender's email address for email notifications. |
| Mail Server Username | Enter the user name for sending email notifications. Some email servers and firewalls treat emails with different sender and user names suspiciously. Therefore, consider specifying the same name for both fields. |
| Mail Server Password | Enter the user password for sending email notifications. |
| Max Recipients Per Email | Specify the maximum number of recipients to include
in a single email. Mutliple emails will be sent when this is exceeded. |
| Resource Type to Run External Approvals | Choose any of the following options:
| Enable "Prompt On Use" | When enabled, the option to set Prompt On Use for properties in workflow steps is displayed. |
| Fail Processes With Unresolved Properties | When enabled, any running process which comes across a property which it cannot resolve will automatically fail. |
| Component Environment Properties Override Environment Properties | When enabled, component environment properties overrides environment properties when using
${p:propName} notation as opposed to
${p:environment/propName}. |
| Enable Deleting Resources From Environment Resource Tree | When enabled, allows you to delete resources that are mapped with environment while deleting
that environment. Note that the resources are deleted globally and affects the other environments that uses the same resource tree. |
| Load Compliancies On Application Page | When enabled, environment compliancies are loaded in batch from the Application page rather than loading on demand. |
