Deploying by using the Job Monitor
You use the Job Monitor to submit jobs and to monitor the job status in your deployment. You must ensure that you have a Job Monitor task running and that you run the HCL Launch process to submit or to monitor the job. Then, you must set up Job Monitor connection properties in your HCL Launch environment.
- z/OS agent
- IBM Developer for IBM Z
- IBM Rational Team Concert
The hlq.SBUZSAMP(BUZJJCL) member has the sample PROC for starting JMON. The hlq.SBUZSAMP(BUZJCNFG) member is the JMON configuration file that is referred to in the PROC. JMON installed for another product (for example, IDz or IBM RTC) can be used, but the LOOPBACK_ONLY property must be OFF
- Start the Job Monitor task and check that a task that is called JMON is running.
- To submit or to monitor jobs, run the process that uses the Submit Job or Wait For Job steps.
- Set the following Job Monitor connection properties in the HCL Launch environment or
resource:
jes.host=localhost jes.user=z/OS user ID jes.password=Password of the user. Set blank to use PassTicket authentication. jes.monitor.port=The port number for Job Monitor host server. The default port is 6715.
Authenticating with a user ID and Password
Authenticating with PassTickets
If you do not provide a password, the plug-in uses PassTickets authentication. You can use PassTickets authentication to eliminate the requirement to store user passwords in HCL Launch.
To configure your system to use PassTickets, complete the following steps:
Activate the RACF PTKTDATA class if it is not already active. The
following code shows sample RACF commands:
SETROPTS GENERIC(PTKTDATA) SETROPTS CLASSACT(PTKTDATA) RACLIST(PTKTDATA) RDEFINE PTKTDATA IRRPTAUTH.FEKAPPL.USER1 UACC(NONE) -
To create a PTKTDATA profile that defines the secret key and the application
name to which it applies for the Job Monitor, complete the following steps:
- Define the application name as FEKAPPL.
- Define the key as a 64-bit number (16 hex characters).
- Replace the key16 placeholder with a user-supplied 16 character hex string (characters 0-9 and
A-F) as shown in the following sample RACF
commands:
RDEFINE PTKTDATA FEKAPPL UACC(NONE) SSIGNON(KEYMASKED(key16)) APPLDATA('NO REPLAY PROTECTION – DO NOT CHANGE') DATA('URBANCODE DEPLOY')The following example shows the command with the key16 value replaced:RDEFINE PTKTDATA FEKAPPL UACC(NONE) - DATA('URBANCODE DEPLOY') - APPLDATA('NO REPLAY PROTECTION - DO NOT CHANGE') - SSIGNON(KEYMASKED(0123456789ABCDEF)) - Read the following scenarios:
- If the PTKTDATA class is already defined, verify that it is defined as a generic class before you create the profile that was shown previously. The support for generic characters in the PTKTDATA class is new in the z/OS V1.7 release, with the introduction of a Java interface to PassTickets.
- If a cryptographic product is installed and available on the system, you can encrypt the secured sign-on application key for added protection. Use the KEYENCRYPTED keyword instead of the KEYMASKED keyword. For more information, see the Security Server RACF Security Administrator's Guide (SA22-7683).
- If the Rational Developer for System z or the Rational Team Concert server components are already installed on the system, the PTKTDATA profile might be defined already.
To define a profile to generate a PassTicket, you must define the IRRPTAUTH
profile in the PTKTDATA class. Then, this profile controls for which user ID a
PassTicket is generated, as shown here:
Operation Profile name Required access Generate PassTicket IRRPTAUTH.application.target-useridUpdate -
To set permissions for the HCL Launch agent to generate a PassTicket so that the agent generates a PassTicket, the user ID of the agent
or the impersonated ID must have UPDATE access in the PTKTDATA
profile that you created in the previous step. For more information, see the following RACF
commands:
PERMIT IRRPTAUTH.FEKAPPL.USER1 CLASS(PTKTDATA) ID(AGNTUSR) ACCESS(UPDATE) -
To refresh the PTKTDATA class for the new profiles and permissions to take
effect, see the following commands:
SETROPTS RACLIST (PTKTDATA) REFRESH
Example
Example 1. Agent is started by user AGNTUSR. In a deployment process, a Job needs to be submitted on behalf of user USER1.
Example 2. Agent is started by user AGNTUSR. Allow this agent to submit jobs on behalf of any user.
RDEFINE PTKTDATA IRRPTAUTH.FEKAPPL.* UACC(NONE)
PERMIT IRRPTAUTH.FEKAPPL.* CLASS(PTKTDATA) ID(AGNTUSR) ACCESS(UPDATE)
Example 3. Agent is started by user AGNTUSR. Allow this agent to submit job on behalf of user AGNTUSR:
RDEFINE PTKTDATA IRRPTAUTH.FEKAPPL.AGNTUSR UACC(NONE)
PERMIT IRRPTAUTH.FEKAPPL.AGNTUSR CLASS(PTKTDATA) ID(AGNTUSR) ACCESS(UPDATE)
What to do next
More JES security considerations are described in the IBM Developer for IBM Z documentation. For more information, see JES Security.
