Power Management settings
The Power Management settings report shows the percentage of computers that have power management settings enabled on a specific day. It can also be set to compare the improvements between two different days. The comparison function requires that historical power tracking is enabled.
Note: If you select the current date as the compare against date, the report might take significantly longer to generate because previous dates are pre-calculated.
