System requirements
IBM Endpoint Manager Power Management supports the following Windows and Mac versions.
- Windows
- Windows XP*
- Windows Vista
- Windows 2003
- Windows 2008
- Windows 2008 R2
- Windows 7
- Windows 8
- Mac OS
- Mac OS 10.4
*Microsoft XP has reached its end of life (EOL). Microsoft products have a lifecycle that ends when the product is no longer supported. When a product reaches EOL or its end of support date, Microsoft no longer supports and releases updates for the product, including automatic fixes, updates, and online technical assistance.
IBM Endpoint Manager, in turn, no longer provides security and non-security content and support for products that reached its end of support date. However, users of existing Windows content can use the standard IBM support channels to raise concerns and for troubleshooting support.
Microsoft provides extended support for some products that have reached their end of life. If you signed for extended support with Microsoft, it is suggested that you contact your IBM account representative. To see information about product offerings, see http://www-01.ibm.com/software/tivoli/services/consulting/contacts.html.
