Sample 2: DAST Scanning through Build Automation
Note: The scan template to be used has to be created. It cannot be
one of the default ones included in the ASE by default(For example: Quick and Light Scan or
Developer Essentials). This demo assumes Manual Explore Server is installed in the default location:
C:\Program Files (x86)\HCL\AppScan Manual Explorer.
The workflow is kicked off when a build of AltoroJ is started in Jenkins.
Workflow:
- Build completes in Jenkins.
Jenkins runs the post build task
python Selenium_StartScan.py dast_auto.config
. - The script starts the manual explore server.
The selenium script
Selenium_Altoro_View_AcctDetails.py
is ran. (Traffic is proxied through the manual explore server). - The M.E.S stopped and traffic capture is saved as an HTD file in the workspace directory.
- A scan job is created in ASE if one is not already there.
- The starting URL is added to the job (old one is overwritten).
- The HTD file is deleted.
- Login type is set to Automatic.
- Test credentials are added to the scan job.
- Scan is run.
- Report Pack is run.
- Security issues are extracted from the Security Issues report.
monkit.xml is updated so that Jenkins can display the graph.
The necessary files to this process are:
dast_auto.config - This is the configuration file for the automation. Edit this file to change the behavior of the script. For example: Change the scan template or starting URL. The file Selenium_StartScan.py has a function to generate a blank config file.
- scans.py - a python library that contains the API calls to ASE.
Selenium_Altoro_ViewAcctDetails.py - A selenium script that logs into AltoroJ, views the account details of the first account and does a search.
Selenium_StartScan.py - a python script that contains the logic described in steps 3 through 14 above. Edit Line #80 to adjust for the Jenkins project folder naming.
- monkit.xml - a file that Jenkins can consume to display results of our security scanning.
geckodriver.log - the auto-generated log file for the geckodriver. The geckodriver is the driver that allows Selenium to interface with firefox via python
