Workstation types
The following are the main workstation types and their attributes.
| Attributes | Master domain manager | Domain manager | Backup domain manager |
| cpuname | The name of the workstation. | ||
| description | A description for the workstation enclosed within double quotes. This attribute is optional. | ||
| vartable | The name of a variable table associated with the workstation. Variables used with the workstation are defined in this table. This attribute is optional. | ||
| os | The operating system installed
on the system. Specify one of the following values:
| node | The system host name or IP address. | ||
| tcpaddr | The value assigned to nm port in
the localopts file. For multiple workstations on
a system, enter an unused port number. The default value is 31111. |
| secureaddr | The value assigned to nm ssl
port in the localopts file. Specify it if securitylevel is
set to on, force or enabled. |
| timezone | tz | The time zone in which the system is located. It is recommended that the value matches the value set on the operating system. | ||
| domain | MASTERDM |
The name of the managed domain. | |
| host | Not applicable | ||
| access | Not applicable | ||
| type | manager |
fta |
| ignore | Use this attribute if you do not want this workstation to appear in the next production plan. | ||
| autolink | It indicates if a link between
workstations is automatically opened at startup. Specify one of the
following values:
ON. |
| behindfirewall | This setting is ignored. | It indicates if there is a firewall
between the workstation and the master domain manager. Specify one
OFF. |
| securitylevel | The type of SSL authentication
to use:
| fullstatus | ON |
| server | Not applicable | This setting is ignored. | |
| protocol | Not applicable | ||
| members | Not applicable | ||
| requirements | Not applicable | ||
Attribute
settings for target workstation types describes
the values you set for each attribute for target workstation types.
Following the table you find additional details about each attribute.
| Attribute | Fault-tolerant agent and standard agent | Workload broker workstation | Extended agent | Agent | Remote engine workstation | Pool | Dynamic pool |
| cpuname | The name of the workstation. | ||||||
| description | A description for the workstation enclosed within double quotes. This attribute is optional. | ||||||
| vartable | The name of a variable table associated with the workstation. Variables used with the workstation are defined in this table. This attribute is optional. | ||||||
| os | The operating system installed on the system.
Specify |
OTHER |
The operating system installed on the machine.
This value setting is discovered on the system. | The operating system installed on the machine.
on the machine. Specify one of the following values:
| node | The system host name or IP address. | The system host name or IP address. Specify NULL when host is
set to $MASTER, or when defining an extended agent
for PeopleSoft, MVS or Oracle. |
Agent host name or IP address. | Remote engine host name or IP address. | Not applicable | ||
| tcpaddr | The value assigned to nm port in the localopts file.
When defining multiple workstations on a system, enter an unused port
port in the localopts file. When defining multiple
workstations on a system, enter an unused port number. The default
value is 41114. |
See the selected access method specifications. | The port number to communicate with the
agent when the protocol is http. |
remote engine when the protocol is http. |
Not applicable | |
| secureaddr | The value assigned to nm ssl port in
Not Applicable | Not Applicable | The port number to communicate with the
agent when the protocol is https. |
remote engine when the protocol is https. |
Not applicable | |
| timezone | tz | The time zone in which the system is located. It is recommended that the value matches the value set on the operating system. | The time zone set on the workstation specified in the host attribute. | The time zone set on the agent. | The time zone set on the remote engine. | The time zone set on the pool agents. | The time zone set on the dynamic pool agents. | |
| domain | Specify an existing domain. The default value
for fault-tolerant agents is MASTERDM. This setting
is mandatory for standard agents. |
Specify an existing domain. This setting is mandatory. | This setting is needed only if the value assigned
to host is $MANAGER. |
Not applicable | |||
| host | Not Applicable | The host workstation. It can be set to $MASTER or $MANAGER. |
The broker workstation. | ||||
| access | Not Applicable | Select the appropriate access method file name. | Not Applicable | ||||
| agentID | The unique identifier of the dynamic agent | ||||||
| type |
fta. Specify |
broker |
x-agent |
agent |
rem-eng |
pool |
d-pool |
| ignore | Use this attribute if you do not want this workstation to appear in the next production plan. | ||||||
following values:
ON. |
OFF |
Not applicable | ||||
| behindfirewall | It indicates if there is a firewall
OFF. |
OFF |
| securitylevel | The type of SSL authentication to use:
Not Applicable | |||||
| fullstatus | It indicates if the workstation is updated about
job processing status in its domain and subdomains. Specify one of
OFF for standard
agents. |
OFF |
| server | 0-9, A-Z. When specified, it requires the creation of a dedicated mailman processes on the parent workstation. | Not Applicable | |||||
| protocol | Not applicable | Specify one of the following
values:
| members | Not applicable | Required value | Not applicable | ||||
| requirements | Not applicable | Required value | |||||
