Adding and removing dependencies
How to add or remove dependencies using the Dynamic Workload Console.
Adding a dependency
- In the workspace, select the job stream to which you want to add a dependency or the job stream containing the job to which you want to add a dependency.
- From the highlighted connection points placed on the outline of job stream or job boxes, drag a connecting arrow and drop it on another job stream or job.
In the properties panel on the right, define the following information about the
dependency:
- Status condition
- Type of dependency resolution
- If you need to modify dependency information, click the dependency arrow and then select the edit icon.
What to do next
Note: If you add a dependency
to a job or job stream after it has completed, it is not evaluated.
However, any subsequent reruns of the job or job stream will process
the dependency correctly.
Removing a dependency
- Select the dependency arrow, and then click the bin icon that appears on the arrow.
- Select the dependency arrow, and then press cancel on your keyboard.
