Adding a job to a job stream
How to add a job to a job stream by using the Dynamic Workload Console.
- Select the engine to which to connect. The Explore area panel opens.
- Select the Job stream card.
- From the list of job streams that is displayed, select the job stream you want and click Edit.
- You can work with the job stream from either the Details view that opens, or from the Graphical view by clicking the related icon.
Adding a job from the Details view
To add a job to the job stream:
- Click the plus button near to Jobs, and depending on your
environment:
- On distributed systems
- Search for the job definition to be added and click Add.
- On z/OS systems
- Select the type of job to be added.
- Edit the properties of the newly added job, optionally specifying its scheduling options and time restrictions. For example, you can set a job as Critical if the job submission is critical and must be processed accordingly.
- Save the job stream.
Adding a job from the Graphical view
- Click the Graphical view icon, and depending on your environment:
- Right-click inside the graphical view and select Add Jobs or search for the required job by using the displayed Search field and add it to the job stream.
- On z/OS systems
- Right-click inside the graphical view and select Add Jobs, then select the type of job to be added to the job stream.
What to do next
