Attributes for security object types
Attributes for security object types shows the attributes that you can specify for each security object
type (see in parenthesis the corresponding object type and object attribute that you must use
when defining security objects with the composer command line interface).
For the values that are allowed for each object attribute, see Specifying object attribute values.
| Attribute | Name (name) | Workstation (cpu) | Custom (custom) | JCL (jcl) | JCLtype (jcltype) | Logon (logon) | Provider (provider) | Type (type) | Host (host) | Port (port) | Folder (folder) | CPU Folder (cpufolder) |
| Security object type | ||||||||||||
| Actions (action) | ✓ | ✓ | ✓ | ✓ | ||||||||
| Calendars (calendar) | ✓ | ✓ | ||||||||||
| Workstations (cpu) | ✓ | ✓ | ✓ | |||||||||
| Events (event) | ✓ | ✓ | ✓ | |||||||||
| Event rules (eventrule) | ✓ | ✓ | ||||||||||
| Files (file) | ✓ | |||||||||||
| Jobs (job) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
| Application Lab (lob) | ✓ | |||||||||||
| Parameters (parameter) | ✓ | ✓ | ✓ | ✓ | ||||||||
| Prompts (prompt) | ✓ | ✓ | ||||||||||
| Reports (report) | ✓ | |||||||||||
| Resource (resource) | ✓ | ✓ | ✓ | |||||||||
| RunCycle groups (runcygrp) | ✓ | ✓ | ||||||||||
| Job streams (schedule) | ✓ | ✓ | ✓ | ✓ | ||||||||
| User objects (userobj) | ✓ | ✓ | ✓ | |||||||||
| Variable tables (vartable) | ✓ | ✓ | ||||||||||
| Workload applications (wkldappl) | ✓ | ✓ | ||||||||||
| Folders (folder) | ✓ |
