Skip to content
<object>.update
The .update API updates the records that are qualified for the criteria in the local database.
This API is supported from V8 SP4 onwards.
Not supported for Windows channel.
* The column names and the values provided as key value pairs are case sensitive.
Volt MX Iris (JavaScript)
Signature
<VMXObj>.update(record, options, successCallback, failureCallback)
Parameters
ParameterTypeDescriptionRequired
recordJSONA dictionary containing column name and value pairs which are to be updated.Yes
optionsJSONThe options parameter accepts a JSON that has the following options keys primaryKeys whereCondition whereConditionAsAString trackChanges trackIntermediateUpdates markForUpload For detailed information, refer Options Keys. If the options parameter is null or empty, all the records are updated.Yes
successCallbackFunctionThe function is invoked when the records are updated successfully.Yes
failureCallbackFunctionThe function is invoked on an error with the cause of failure as an argument.Yes
Options Keys
Keys Type Description Required
primaryKeys JSON Specify the primary keys of the record to be updated. Key Name: primaryKeys and values are column names and their respective values. No
whereCondition JSON Specify the where condition for the update query. Key Name: whereCondition and values are column names and their respective values. No
whereConditionAsAString String Specify the where condition for the update query. Key Name: whereConditionAsAString and the value is a string. > Note: For SPA/Desktop Web channels, each condition must have only one comparison operator (=,!=,>,<,>=,<=). Multiple conditions can be clubbed using conjunctions (AND, OR). Values containing whitespaces are not supported. No
trackChanges Boolean If trackChanges is set to False, the record level operations are not tracked. When the option is set to false, the CUD operations performed on a record are not synced (uploaded). The key is set to True, by default. > Note: Not supported for SPA/Desktop Web channels. No
trackIntermediateUpdates Boolean If trackIntermediateUpdates is set to False, it enables to track the latest update performed on the record. The key is set to True, by default. > Note: Not supported for SPA/Desktop Web channels. No
markForUpload Boolean If markForUpload is set toFalse, the record changes are not uploaded to the server. The key is set to True, by default. > Note: Not supported for SPA/Desktop Web channels. No
Return Type
void
Example
**//------- update all records -------**
var category = new voltmx.sdk.VMXObj("CATEGORY");
var record = {};
record["CATEGORY_DES"] = "Update existing record";
function successCallback(response)
    //response holds the number of records updated
function errorCallback(error)
    voltmx.print("Update failed with error: " + JSON.stringify (error));
category.update(record, null, successCallback, errorCallback);
**//--------update a record using primary key--------**
var options = {};
var record = {};
var primaryKeys = {};
primaryKeys["CATEGORY_ID"] = "1234";
options["primaryKeys"] = primaryKeys;
category.update(record, options, successCallback, errorCallback);
**//------- update by whereCondition-------**
var options = {};
var record = {};
var whereClause = {};
whereClause["Category_PN"] = 7;
options["whereCondition"] = whereClause;
    voltmx.print("Update failed with error: " + JSON.stringify(error));
**//------- update by whereConditionAsAString -------**
var options = {};
var record = {};
var whereClause = "Category_PN = '7'";
options["whereConditionAsAString"] = whereClause;
**//------- update using Disable change tracking flag - trackIntermediateUpdates ---------**
var options = {"trackIntermediateUpdates": false};
var VMXObject = new voltmx.sdk.VMXObj("CATEGORY");
VMXObject.update(record, options, successCallback, errorCallback);
**//------- update using Disable change tracking flag – trackChanges ---------**
var options={"trackChanges": false};
**//------- update using markForUpload flag ---------**
var options={"markForUpload": false};
Android (Java)
Signature
void <VMXObj>.update(HashMap<String, Object> record,
                      HashMap<String, Object> options,
                final VMXCallback callback) throws Exception
Parameters
recordHashMap<String, Object>A HashMap containing column name and value pairs which are to be updated.Yes
optionsHashMap<String, Object>The options parameter accepts a HashMap with the following option keys: primaryKeys whereCondition whereConditionAsAString trackChanges trackIntermediateUpdates markForUpload For detailed information, refer Options Keys. If the options parameter is omitted, all the records are updated.Yes
callbackVMXCallbackApplication implements onSuccess and onFailure methods of VMXCallback interface.Yes
Options Keys
KeysTypeDescriptionRequired
primaryKeysHashMap<String, Object>Specify the primary keys of the record to be updated. Key Name: primaryKeys and values are column names and their respective values.No
whereConditionHashMap<String, Object>Map of column names and their respective values according to which the records are to be updated.No
whereConditionAsAStringStringSpecify the where condition for the select query. Key Name: whereConditionAsAString and the value is a string. Note: For SPA/Desktop Web channels, each condition must have only comparison parameter (=,!=,>,<,>=,<=). Multiple conditions can be clubbed using conjunctions(AND, OR). Values with whitespaces are not supported.No
trackChangesBooleanIf trackChanges is set to False, the record level operations are not tracked. When the option is set to false, the CUD operations performed on a record are not synced (uploaded). The key is set to True, by default.No
trackIntermediateUpdatesBooleanIf trackIntermediateUpdates is set to False. The option enables us to track the latest update performed on the record. The option is set to True, by default.No
markForUploadBooleanIf markForUpload is set to false, the record changes are not uploaded to the server. The option is set to True, by default.No
Return Type
void
Example
//Update record with a primary key
VMXObj category = new VMXObj("CATEGORY");
HashMap<String, Object> record = new HashMap<String, Object>();
record.put("CATEGORY_PN", "7");
record.put("CATEGORY_DES", "new updated description");
HashMap<String, Object> primaryKeys = new HashMap<>();
primaryKeys.put("CATEGORY_ID", "123");
HashMap<String, Object> options = new HashMap<>();
options.put("primaryKeys", primaryKeys);
try{
  category.update(record, options, new VMXCallback()
    @Override
    public void onSuccess(Object object)
      Log.d("Object Update", "Object Update Successful for category");
    @Override
    public void onFailure(Object error)
      OfflineObjectsException e=(OfflineObjectsException)error;
      Log.e("Object Update", "Object Update Unsuccessful for category with Error :" + e.getMessage());
catch(Exception e)
    Log.e("Object Update"."Object Update Unsuccessful with error: " + e.getMessage());
//Update record with composite primary key
primaryKeys.put("CATEGORY_KEY1", "123");
primaryKeys.put("CATEGORY_KEY2", "124");
try{
    @Override
    @Override
catch (Exception e)
//Update record using whereCondition
HashMap<String, Object> whereClause = new HashMap<>();
whereClause.put("CATEGORY_ID", "123");
options.put("whereCondition", whereClause);
try{
    @Override
    @Override
catch(Exception e)
//Update record using whereConditionAsAString
String whereClause = "CATEGORY_ID = 123";
options.put(“whereConditionAsAString”, whereClause);
try
    @Override
    @Override
catch(Exception e)
//Disable change tracking - trackIntermediateUpdates
HashMap<String, Object>options=new HashMap<>(); options.put(KSPublicConstants.TRACK_INTERMEDIATE_UPDATES, false); category.update(record, options, new VMXCallback(){
@Override
@Override
public void onFailure(Object object)
//Disable change tracking - trackChanges
HashMap<String, Object> options = new HashMap<>(); options.put(KSPublicConstants.TRACK_CHANGES, false);
@Override
@Override
//Mark for Upload
HashMap<String, Object> options = new HashMap<>(); options.put(KSPublicConstants.MARK_FOR_UPLOAD, false);
@Override
@Override
iOS (Objective C)
Signature
void <VMXObj>.update:(NSDictionary<NSString *, id> *)record
             options:(NSDictionary<NSString *, id> *)options
           onSuccess:(VMXSuccessCompletionHandler)onSuccess
           onFailure:(VMXFailureCompletionHandler)onFailure
Parameters
recordNSDictionary<NSString*, id>A dictionary containing column name and value pairs which are to be updated.Yes
optionsNSDictionary<NSString*, id>The options parameter accepts a NSDictionary with the following option keys: primaryKeys whereCondition whereConditionAsAString trackChanges trackIntermediateUpdates markForUpload For detailed information, refer Options Keys. If the options parameter is null or empty, all the records are updated.Yes
onSuccessVMXSuccessCompletionHandlerThe function is invoked when records are updated successfully.Yes
onFailureVMXFailureCompletionHandlerThe function is invoked when updating records fail with the cause of failure.Yes
Options Keys
primaryKeysNSDictionary<NSString*, id>Specify the primary keys of the record to be updated. Key Name: primaryKeys and the values are column names and their respective values.No
whereConditionNSDictionary <NSString*, id>Dictionary of column names and their respective values according to which the records are to be updated.No
whereConditionAsAStringNSStringSpecify the where condition for the update query. Key Name: whereConditionAsAString and the value is a string.No
trackChangesBooleanIf trackChanges is set to False, the record level operations are not tracked. When the option is set to false, the CUD operations performed on a record are not synced (uploaded). The option is set to True, by default.No
trackIntermediateUpdatesBooleanIf trackIntermediateOptions is set to False, it enables to track the latest update performed on the record. The option is set to True, by default.No
Return Type
void
Examples
**// Update record with a primary key**
VMXObj *_categories = [[VMXObj alloc] initWithName:@"CATEGORY" error:&error];
NSMutableDictionary *recordToUpdate = [NSMutableDictionary new];
recordToUpdate[@"CATEGORY_DES"] = @"updated description";
recordToUpdate[@"CATEGORY_PN"] = @"3";
NSMutableDictionary *options = [NSMutableDictionary new];
NSMutableDictionary *primaryKeys = [NSMutableDictionary new];
primaryKeys[@"CATEGORY_ID"] = @"112";
options[@"primaryKeys"] = primaryKeys;
[_categories update:recordToUpdate
        options:options
          onSuccess:^ (id object)
            NSLog(@"Update record succeded");
          onFailure:^(id object)
            OfflineObjectsError *error=(OfflineObjectsError)object;
NSLog(@"Update record failed with error %@",
[error.userInfo localizedDescription]);
**// Update record with composite primary key**
primaryKeys[@"PRIMARY_KEY1"] = @"123";
primaryKeys[@"PRIMARY_KEY2"] = @"222";
            options:
        onSuccess:^(id object)
            NSLog(@"Updated successfully");
**// Update record using whereCondition**
NSMutableDictionary *whereClause = [NSMutableDictionary new];
whereClause [@"CATEGORY_ID"] = @"112";
options[@"whereCondition"] = whereClause;
        options:options
**// Update record using whereConditionAsAString**
NSString *whereClause = @"CATEGORY_ID = 112";
options[@"whereConditionAsAString"] = whereClause;
         options:options
**//Disable change tracking - trackIntermediateUpdates**
NSDictionary <NSString*, id> *options=@{VMXCONSTANTS_TRACK_ INTERMEDIATE_UPDATES: @NO};
[sdkObjectSync update:record
         options:options
        onSuccess:^(id object){}
        onFailure:^(id object){}
**//Disable change tracking - trackChanges**
NSDictionary <NSString*, id> *options=@{VMXCONSTANTS_TRACK_CHANGES_ UPDATES: @NO};
         options:options
**//Mark for Upload**
NSDictionary <NSString*, id> *options=@{VMXCONSTANTS_MARK_FOR_ UPLOAD: @NO};
         options:options
  • The trackChanges flag must be used consistently (either always true or always false) for all CUD operations on a record. You must not update the value of "change tracking" flag in between CUD operations on a record.
  • When you set both markForUpload and trackChanges flags, an error is reported as these are mutually exclusive options.
  • When the user sets both trackIntermediateUpdates and trackChanges flags, an error is reported as these are mutually exclusive options.
  • For Hierarchical Objects, you must provide a proper value for both parent and child record operations.
  • The primaryKeys, whereCondition, and whereConditionAsAString are considered as the criteria to update a record. Only one criterion is considered at a time and the order is primaryKeys> whereCondition > whereConditionAsAString.
RevAuthorEdits
1.0PKPK
1,1GSGS
