Voltmx foundry manual install guide
Volt MX Foundry
Volt MX Foundry - Manual Install Guide
Applicable to on-premises. This document explains how to install Console, Identity, Integration Services, and Engagement Services manually for secured environments.
Revision History
| Date | Document Version | Description of Modifications/Release |
| 02/20/2020 | 1.0 | Document Published for V9 GA |
Getting Started Options
- Release Notes: Provides release details and information on the new features, known issues, and limitations.
- VoltMX Foundry User Guide: Provides information on the features and the procedure to perform various tasks.
HCL recommends using the Volt MX Foundry Installer for deploying Volt MX Foundry V9.0 onwards.
If you want to install Volt MX Foundry manually due to your business rules and policies, please contact support@voltmx.com for approval and to obtain access to the Volt MX Foundry manual install artifacts.
Manual installs not approved by HCL will not be supported.
