Clara is installed using Docker.
You can install Clara on Linux 64 bit operating system.
Clara V2 is available also on HCL Software Factory (SoFy), a catalog of Kubernetes enabled products that can be deployed to a cloud-native environment. For Clara on SoFy System Requirements, see HCL SoFy Guides.
Google Chrome 67.0.3396.99 or higher
Mozilla Firefox 61.0.1 or higher
Microsoft Edge 79 or higher
Docker 20.10+
Docker Compose 1.29.0+
Red Hat Linux 7.5+
CentOS 7.5-1804+
Clara must be installed and configured with the following minimum requirements:
CPU 64 bit, 4+ core
RAM 8GB+ (recommended 16GB)
Storage 100GB HDD
Clara can assist Workload Automation users starting from WA version 9.5 fix pack 4.
Clara can assist Universal Orchestrator users starting from UnO version 1.1.
