Clara is installed using Docker.
You can install Clara on Linux 64 bit operating system.
Starting from Clara V1.0.0.6, Clara can also be deployed on HCL SoFy. For details, access the SoFy catalog.
Google Chrome 67.0.3396.99 or higher
Mozilla Firefox 61.0.1 or higher
Microsoft Edge 79 or higher
Docker 17.12.0+
Docker Compose 1.29.0+
Red Hat Linux 7.5+
CentOS 7.5-1804+
Clara must be installed and configured with the following minimum requirements:
CPU 64 bit, 4+ core
RAM 8GB+ (recommended 16GB)
Storage 100GB HDD
Clara can assist Workload Automation users starting from WA version 9.3 fix pack 4.
