During the installation, to enable Clara interaction with multiple Workload Automation environments, you must properly configure the CLARACONFIGWA keyword in the <BUILD_DIR>/clara/config/Clara-WA.env.TEMPLATE file. For Workload Automation for z, configure the CLARACONFIGWAZ keyword.
This keyword contains a json object (envs) with informations about the different Workload Automation environments. See the examples below.
After Clara installation, if a re-configuration is needed (for example to integrate Clara in the Dynamic Workload Console), or you want to enable Clara interaction with additional Workload Automation environments, you must modify the .env file created during the installation process and located in the folder <BUILD_DIR>/clara.
After you have modified the .env file, run the following command to activate the updates:
clara.sh --up --nc
In Example 1, envs contains only one environment named WA-PROD.
Example 1
For Workload Automation:
CLARACONFIGWA = '{"envs": { "WA-PROD": {"ip": "mdm-host.example.com", "port": "31116", "engineId": "engine_wa-server", "dwcGrp":"DWC-1"}}, "dwcEnvsGrp":{ "DWC-1":{"dwcIp":"dwc-host.example.com", "dwcPort": "16311"}}, "license" : {"licenseServer":"https\://hclsoftware.compliance.flexnetoperations.com/instances/", "licenseID" : "38K36F2YXS18"}, "tkt_url":"https://servicenow.com", "product":"WA"}'
For Workload Automation for z:
CLARACONFIGWAZ = '{"envs": { "WA-PROD": {"engineId": "engine_wa-server", "dwcGrp":"DWC-1"}}, "dwcEnvsGrp":{ "DWC-1":{"dwcIp":"dwc-host.example.com", "dwcPort": "16311"}}, "license" : {"licenseServer":"https\://hclsoftware.compliance.flexnetoperations.com/instances/", "licenseID" : "38K36F2YXS18"}, "tkt_url":"https://servicenow.com", "product":"WAz"}'
If you want to add another environment, you must add another element with all the requested information. In Example 2, envs contains two environments named Bot1 and Bot2.
Example 2
CLARACONFIGWA = '{"envs": { "Bot1": {"ip": "54.89.190.168", "port": "", "engineId": "engine_waadmin", “dwcGrp”: ”dwcGroup1”}, "Bot2": {"ip": "192.168.1.15", "port": "", "engineId": "engine_waadmin"}}, "dwcEnvsGrp":{ “dwcGroup1”:{"dwcIp":”localhost”, "dwcPort": ""}},"product":"WA", "license" : {"licenseServer":"https\://flex1513-uat.compliance.flexnetoperations.com/instances/" , "licenseID" : "38K36F00XS18"},"tkt_url":"https://servicenow.com"}'
For each environment, you specify the following information:
env_name, the name of the Workload Automation environment. It is used as an index for the envs json objects. In the above example, “Bot1” and “Bot2” are the environment names.
ip, the hostname of the Workload Automation engine (not needed for Workload Automation for z)
port, the port to connect the Workload Automation engine (not needed for Workload Automation for z)
engineId, the name of the engine definition within Workload Automation
dwcGrp, the name of the group which contains information about the connection with the Dynamic Workload Console. If not specified, the environment will get the connection inside the “default” group.
In addition to the envs json object, the dwcGrp json object can also be configured.
The dwcGrp json object defines one or more groups to set the connection to the Dynamic Workload Console. For each group, you must specify the following information:
groupName, the name of the group. It must match the dwcGrp property of the envs object
dwcIp, the hostname of the Dynamic Workload Console
dwcPort, the port of the Dynamic Workload Console
Moreover, you specify:
product, the ID of the product managed by Clara (WA or WAz)
licenseServer, the hostname of the License Service (Default: https://flex1513.compliance.flexnetoperations.com/instances/)
licenseID, the unique ID of your Clara license
tkt_url, the Url to Service Platform for Ticketing
threadpull_size, the number of monitoring processes that Clara can manage simultaneously (Default: 50) - Optional parameter
In the dwcGRP json, if you set “default” as groupName, all the envs that do not have dwcGrp specified will get the default connection. See the following example.
Example 3
CLARACONFIGWA = '{"envs": { "Bot": {"ip": "localhost", "port": "", "engineId": "engine_waadmin"}}, "dwcEnvsGrp":{ “default”:{"dwcIp":”localhost”, "dwcPort": ""}},"product":"WA", "license" : {"licenseServer":"https\://flex1513-uat.compliance.flexnetoperations.com/instances/" , "licenseID" : "38K36F11XS18"},"tkt_url":"https://servicenow.com"}'
