Clara is installed using Docker. Starting from Clara V1.0.0.6, Clara can be also deployed on Kubernetes.
You can install Clara on Linux 64 bit operating system.
Google Chrome 67.0.3396.99 or higher
Mozilla Firefox 61.0.1 or higher
Microsoft Edge 79 or higher
Docker 17.12.0+
Docker Compose 1.29.0+
Red Hat Linux 7.5+
CentOS 7.5-1804+
For system requirements for Clara deployment on Kubernetes, see the dedicated readme file.
Clara must be installed and configured with the following minimum requirements:
CPU 64 bit, 4+ core
RAM 8GB+ (recommended 16GB)
Storage 100GB HDD
Clara can assist Workload Automation users starting from WA version 9.3 fix pack 4.
