Clara replies to your questions
Clara is the product expert that you can consult to learn the product capabilities.
Clara answers "What can I do?" and "How can I do it?" types of questions by leveraging a specialized Knowledge Base, and also provides useful links to videos, blogs, articles, and product documentation.
The current Knowledge Base includes answers to the most Frequently Asked Questions(FAQs) about Workload Automation, many of which come from Customer Support cases and are certified by Workload Automation specialists.
See below for examples about frequently asked questions handled by Clara.
If your question is not clear enough to Clara, she displays several choices and asks you to select one. You can also select:  “None of above”, and Clara will provide additional options.
Semantic search
If you select "None of above" twice in a row, to increase the response rate Clara uses an advanced semantic search engine combined with machine learning technologies to search in two different sources of information:
and provides links to the 5 most relevant search results.
You can even ask for a semantic search directly, by typing "Search"  followed by the subject you want to search. Example: Search how to be notified if a job fails.
Clara can also help you understand the meaning of Workload Automation error messages: ask Clara "Search <error_message_code>, or "Search error <error_message_code>" to get an explanation of the error message you've received.
Example of FAQs from a Workload Automation Operator
Example of FAQs from a Workload Automation Administrator
