System Requirements
Clara is installed using Docker.
You can install Clara on Linux 64 bit operating system.
Supported browsers
Software requirements
Hardware requirements
Clara must be installed and configured with the following minimum requirements:
Workload Automation requirements
Clara can assist Workload Automation users starting from WA version 9.3 fix pack 4.
