Schema generation for an SAP IDoc or DXOB file
When you want to generate the test data for an SAP IDoc or DXOB file, then you must generate a schema for the selected SAP IDoc or DXOB file.
The SAP IDoc or DXOB file is a standard data structure in SAP applications to transfer data between SAP system applications and external resources. Every SAP IDoc or DXOB file has a unique number.
If you have an SAP IDoc or DXOB file that you want to use for test data generation in your local file system, then you must import the file into your HCL OneTest™ Data project. After importing the file, you must establish a connection between the SAP IDoc or DXOB interface and HCL OneTest™ Data. The established connection helps to transfer and interpret the data of the imported SAP IDoc or DXOB file. The interpreted information then helps HCL OneTest™ Data to generate a schema.
You must perform the following tasks to generate a schema in HCL OneTest™ Data for the SAP IDoc or DXOB file:
