Creating BigFix® Remote Control server installation tasks
With the BigFix® Remote Control Server Installer Wizard, you can create an installation task to install a remote control server.
Run the task on a Windows™® system or Linux™ (Red Hat and SUSE) systems to install a fully functional, self-contained BigFix® Remote Control server with either of the following component setups:
  • BigFix® Remote Control server with WebSphere® Application Server Liberty Profile version and a Derby database.
  • BigFix® Remote Control server with WebSphere® Application Server Liberty Profile version and one of the following databases:
    • IBM DB2 10.x, 11.x Workgroup(WSE) and Enterprise Edition(ESE).
    • Oracle 11g and 12c.
      When you use an Oracle database, if you are using the Oracle 11g drivers, set oracle.increment.keys.off=1 in the trc.properties file. Restart the server service.
    • Microsoft SQL server 2008, 2012, 2014, and 2016.
      You must use a JDBC driver whose version is bigger than 6.3. Older versions do not support TLS1.2 or JRE8.
      When you use an MS SQL database, Windows™ authentication is not supported. You cannot log on with a domain user. You must use mixed mode authentication and create an SQL user to connect to the database.
  1. If you choose the DB2®, MS SQL or Oracle database options, you must install the database and create a database instance before you run the server installation task.
  2. If you are using DB2® 9.7 GA version, you must upgrade to DB2® 9.7 fix pack 1 due to a DB2® issue where NULL values are returned in generated key values.
To access the BigFix® Remote Control Server Installer Wizard, complete the following steps:
  1. In the BigFix® Remote Control navigation tree, select Manage Configurations > BigFix® Remote Control Server Installer Wizard.
    Server installer wizard
  2. Set your configuration values by using one of the following options.
    Load Settings from Existing Task
    The wizard initially displays server configuration default values that you can change to your own requirements. To load previously saved settings, complete the following steps.
    1. Click Load Settings from Existing Task.
    2. On the Wizard Fixlets screen, select the task.
      Choose a server installation task from the displayed list
    3. Click Load Wizard with Fixlet. The configuration values are loaded into the wizard.
    4. Follow the steps in Create a new configuration task to create a new configuration task.
    Reset to default values
    You can use this feature to clear any selections that are made and return the values in the wizard to the default configuration values.
    Follow the steps that are relevant to the database that you are using.
