Configure the user acceptance window for a peer to peer session
When you use the Configure session dialog feature in the BigFix® Remote Control Server UI and save customized locales, thee values are saved to the database. When a remote control session is requested, the values are passed to the target computer to be saved in the properties. You can configure the properties locally on the target if the target takes part in peer to peer sessions only.
Note: If you set values locally for the properties and the target takes part in remote control sessions started from the server, the local values are overwritten with values passed from the server.
CustomConfirmTitle
Use this property to define a customized window title for the user acceptance window. When there is no translation available for the locale that the target is configured for, the default string, that is saved in CustomConfirmTitle, is displayed for the window title. If you want a customized window title for specific locales, you can create multiple CustomConfirmTitle.X properties, where X is the locale. For example, CustomConfirmTitle.fr.
ConfirmExtraText
Use this property to define a customized Paragraph 1 for the user acceptance window. When there is no translation available for the locale that the target is configured for, the default string, that is saved in ConfirmExtraText, is displayed for Paragraph 1. If you want a customized Paragraph1 for specific locales you can create multiple ConfirmExtraText.X properties, where X is the locale. For example, ConfirmExtraText.es.
CustomConfirmOptions
Use this property to define a customized Paragraph 2 for the user acceptance window. When there is no translation available for the locale that the target is configured for, the default string, that is saved in CustomConfirmOptions, is displayed for Paragraph 2. If you want a customized Paragraph 2 for specific locales, you can create multiple CustomConfirmOptions.X properties, where X is the locale. For example, CustomConfirmOptions.zh.
AllowSessionModeOverride
Use this property to determine whether the session mode buttons that are valid for the session are displayed on the acceptance window.
Set to Yes.
The session mode buttons that are valid for the remote control session are not displayed on the user acceptance window.
Set to No.
The session mode buttons that are valid for the remote control session are displayed on the user acceptance window.
