Configuring target properties
When a target takes part in a peer to peer remote control session, its properties determine what functions are available during the session. Target properties can be configured by creating and running a target configuration task in the IBM® BigFix® console. For more details see the, IBM BigFix Remote Control Console User's Guide. You can also edit the target properties manually.
Editing the target properties on a Windows target
- Edit the target registry and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\IBM\Tivoli\Remote
Control\TargetNote: On a 64 bit system all the 32-bit registry keys are under the Wow6432Node key, for example: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\IBM\Tivoli Remote Control\Target
- Right-click the required property and select Modify
- Set the required value and click OK.
- Restart the target service.
Editing the target properties on a Linux target
- Edit the ibmtrct.conf file.
- Modify the required properties.
- Save the file.
