Understand the relationship between HCL BigFix patch categories and Microsoft standard
terminology (KB824684), including legacy terms and BigFix exclusive categories.
BigFix generally tries to stay close to the terms used by vendors. For terminology that
Microsoft uses for patch category information, HCL BigFix refers to Microsoft information sources
that are available to the public. There are some differences in the terms used by Microsoft and
the HCL BigFix content. This might be caused by changes that Microsoft made to the category
names.
In some instances, BigFix retains legacy terminology in the content. Due to legacy issues,
there are a number of Fixlets in HCL BigFix that are still categorized with the previous terms
used. It is taken into account that existing users might write scripts on top of the BigFix
Server and might already have mature work flows and script systems in place.
The following table provides a guideline for HCL BigFix terms and their Microsoft equivalents
based on
KB824684.
Table 1. HCL BigFix and Microsoft Category Mapping
| Current HCL BigFix Category |
Current Microsoft Category (KB824684) |
| Critical Updates |
Critical Update |
| Update Rollup |
Update Rollup |
| Update |
Update |
| *Updates |
Update |
| Security Update |
Security Update |
| *Security Hotfix |
Security Update |
| Hotfix |
Hotfix |
| Service Pack |
Service Pack |
| Security Advisory |
Security Update |
| Definition Update |
Definition Update |
| *Rollup |
Update Rollup |
| Feature Pack |
Feature Pack |
| *Security Setting |
N/A |
| Microsoft Unsupported |
N/A |
| Setting |
N/A |
| Bug Fix |
N/A |
| Audit |
N/A |
| Undo Workaround |
N/A |
| Workaround |
N/A |
Note: Categories marked with an asterisk (*) will no longer be used
in future Fixlet releases. However, Fixlets created before the terminology update might still
use these legacy terms.
BigFix Defined categories
The following categories are unique to HCL BigFix and do not have a direct Microsoft
equivalent:
- Microsoft Unsupported
- A category which provides Fixlets to help users to identify End Of Life Microsoft
products.
- Setting
- A category which provides Fixlets that help to set a specific configuration to the system
before or after a patch deployment.
- Bug Fix
- A category which provides Fixlets that remediate bugs.
- Audit
- A category which provides Fixlets that alert users about an issue.
- *Security Setting
- A category which provides audit Fixlets that alert users about security-related issues.
Fixlets with the Security Setting category do not patch but have an Action for users that opt
to turn off the flag to make the Fixlet non-relevant.
- Undo Workaround
- A category which contains Fixlets that undo a previously applied Security Advisory
Workaround.
- Microsoft Security Advisory has two types of patches: the first type uses installable
patches and the second type are workarounds that do not have any installable patches. The new
BigFix category, 'Undo Workaround', covers content to disable and undo the second type.
- Workaround
- A category which provides Fixlets for Microsoft content that do not provide patches. This
content sometimes come with a "Here's an easy fix" section that instruct users to manually
act on a fix, or to use the Easy Fix tool. Workaround Fixlets have actions that automate
Microsoft's instructions for fixes, such as changing registry keys or running the Easy Fix
tool. This content might initially be released by Microsoft as security or non-security
content. An example of a Workaround Fixlet is KB3125869 (under MS15-124), which provides users with instructions for
download options that fix a security feature bypass.
