Uninstalling the Automation Plan Engine (Multinode)
To uninstall the Automation Plan Engine (Multinode), you run a Task from your BigFix console. The Task to uninstall the Automation Plan Engine (Multinode) becomes relevant when you install the Automation Plan Engine (Multinode).
Complete the following steps to uninstall the Automation Plan Engine (Multinode).
- Log on to the BigFix console as the master operator and go to the Server Automation domain.
From the Automation node, click Setup and
Maintenance > Fixlets and Tasks and select the
Uninstall Automation Plan Engine (Multinode)Task, irrespective of your platform. - Click Take Action.
- From the Take Action dialog box, target the system on which the BigFix server is installed.
- Click OK. After uninstallation, the Install and Configure Latest Automation Plan Engine (Multinode) installation Task becomes relevant. The uninstallation Task becomes non-relevant.
