Installing the New Automation Plan Engine (Multinode)
You can install the Automation Plan Engine (Multinode) on Windows® and Linux® systems. To install the Automation Plan Engine (Multinode), you run a Task from your BigFix console. The Task to install the Automation Plan Engine (Multinode) becomes relevant only if the plan engine is uninstalled correctly. The Automation Plan Engine (Multinode) can be installed on any BES Client machines that are reporting to the BigFix server. The installation procedure is the same for both Windows® and Linux®.
Complete the following steps to install the Automation Plan Engine (Multinode).
Log on to the BigFix console as
the master operator and
navigate to the Server Automation domain.
Note: For a Linux® installation,
- the console must be installed on Windows®.
- ensure if
dos2unixpackage is available for RHEL (To check this, open the terminal with Admin privilege/root access and enter the commanddos2unix. If the command is not found, install the package using the commandyum install dos2unix).
- From the Automation node, click Setup and Maintenance > Fixlets and Tasks and select the Install and Configure Latest Automation Plan Engine (Multinode) task from Tasks, irrespective of your platform.
- Click Take Action.
- From the Take Action dialog box, target the system on which the BigFix server is installed.
Click OK. The Task runs and installs the
Automation Plan Engine (Multinode). The default location for the Automation Plan Engine (Multinode)
installation is in the following directory:
- For Windows® platforms, the C:\Program Files (x86)\BigFix Enterprise\BES Client\Applications\PlanEngine directory.
- For Linux® platforms, the /var/opt/BESClient/Applications/PlanEngine directory.
pe_console.log, is available in the following location, depending
on your platform:- For Windows®, the
pe_console.loglog file is available in the \BES Client\Applications\Logs subdirectory of the installation directory, for example, C:\Program Files (x86)\BigFix Enterprise\BES Client\Applications\Logs directory. - For an installation with default values on Linux®, the
pe_console.loglog file is available in the /var/opt/BESClient/Applications/Logs directory.
Remember:
To verify that the Automation Plan Engine (Multinode) is installed
correctly and has started, check for the following lines at the start of the log
file:Before scheduling or executing an
automation plan, ensure that the deployed instances are accurately reflected in the
Plan Engine Instance Information analysis.
2013-08-23 13:15:20,235 INFO [main] (cli.PlanEngineLauncher:255) :: IZNENG025I \
Plan Engine (build number 0.49) starting in JVM with PID (4508) ...
2013-08-23 13:15:20,235 INFO [main] (cli.PlanEngineLauncher:259) :: IZNENG026I \
Plan Engine CLI initializing ...
2013-08-23 13:15:20,235 INFO [main] (cli.PlanEngineLauncher:130) :: IZNENG001I \
Received command: "start"
