Installing the Automation Plan Engine (Multinode) (from SA Plan Engine version 9.5.72 onwards)
To install the Automation Plan Engine (Multinode), you must have BigFix V11.x with the Server Automation site installed. Make sure that your system meets all of the prerequisites before you begin installing the Automation Plan Engine (Multinode). You can then install the Automation Plan Engine (Multinode) by executing a Task from your BigFix console.
In a DSA environment, do not install PlanEngine and PlanDistributionService on the Secondary Server. They should be installed only on the Primary Server (Active) and its BES Client machines.
Install the Automation Plan Engine (Multinode) by completing the following steps:
  1. Read the documentation for important information about the installation.
  2. Complete the prerequisites. After you have completed the prerequisites, you are ready to install the Automation Plan Engine (Multinode) and the Task that installs the Automation Plan Engine becomes relevant.
  3. Run the Task that installs the Automation Plan Engine (Multinode) on the BigFix client. The installation takes a few minutes and when it has completed, the Task that installs the Automation Plan Engine (Multinode) is no longer relevant.
  4. Verify that the Automation Plan Engine (Multinode) installed successfully and has started. It will be started by the windows task scheduler plan engine as per the interval set while installing the plan engine.
The following sections describe each of these steps in detail.
